05-19-2010 12:37 PM
I am using the PXI-8331, PCI-8331 MXI-4 to control chassis PXI-1042. I installed the cards, software and connect chassis to the desktop. MAX window recognizes the chassis but on the chassis status under General tab, a message of "The MXI- connection to this chassis timed out" appears. For this reason, I could not see other modules on the chassis.
How do I solve this problem?
Phuc
05-20-2010 01:51 PM
Hi Phuc,
It looks like there is already a discussion forum discussing the same issue: PXI MXI chassis timeout
05-20-2010 03:16 PM
Thank you for your advise.
I powered on the PXI chassis prior to turn on the desktop computer. The system is now working properly all modules on the PXI chassis were detected.
Thanks again.
Phuc
