PXI
PXIe-5110 Scope error 1074097800
I’m having trouble getting the scope to work.
It keeps throwing the error shown in the attached image at the initialize step.
I tested it using NI-Scope’s own example VI, but it still doesn’t work. Additionally, it won’t perform self-calibration in NI MAX, claiming that the resource is in use—even though LabVIEW and TestStand are not running.
The self test in NI-MAX is ok.
(534 Views)
What are the versions of Windows, LabVIEW and NI-Scope? Make sure they are compatible. If you have confirmed that they are compatible, try reinstalling NI-Scope ddriver.
https://tmesystems.net/
(521 Views)
Accepted by MuaDib
Windows 10, LabVIEW 2018 SP1 and NI-SCOPE 18.7.0.
The problem was solved after rebooting the computer.
(516 Views)
