PXI
PXIe-8031 in PXIe-1082 causing Driver Verifier DMA Violation BSOD on Win10
The current guidance I've received is that Microsoft will be publishing a fix near the end of May.
Message 31 of 33
(1,001 Views)
Microsoft has begun offering the fix for this problem for Windows 10 20H2 and above as KB5014023.   It is not mentioned in the release notes, but I've been assured that the fix is there, and my limited testing bears it out.
Message 32 of 33
(965 Views)
After installing update KB5014023, the PXI-4071 DMM in PXIe-1090 chassis starts working with HP OMEN 17-cb0019nm (7SE79EA) laptop.
Thank you,
Bojan
Message 33 of 33
(948 Views)
