PXI
PXIe 8880 display Issue
PXIe 8880 is not showing any kind of display.
i have checked in multiple chassis .other controllers are working..
fault led glows green
on start drive led (orange) glows in pulses for 2 to 3 times then stops..
monitor goes in sleep mode as there is no signal
kindly suggest something even bios screen is not showing
(1,777 Views)
How are you connecting to the monitor? Through a VGA adapter, a DVI adapter, etc?
Are you able to power it up and remotely log into it? If no, then it may just be that something failed on the controller and it's just not booting up.
(1,743 Views)
Please try the steps in the troubleshooting section of the user manual
Santhosh
Soliton Technologies
(1,737 Views)
through VGA adapter
(1,711 Views)
its RAM was faulty.
New RAM solved the problem.
Faulty RAM was preventing controller to start.
Thanks for your Time
(1,709 Views)
