PXI
PXIe limit on acquisition speed
Hi everyone,
I am running the PXIe-5114 with the PXIe-8861 on a PXIe-1071 chassis.
I am trying to send 5MBytes/s of the data to the NI PC. I run a consumer-producer loop with one queue using the multi-fetch function and ended up reaching my max acquisition speed with something slightly below 1MB/s.
I modified my program to make sure to use two processors to recover the data even if I still kept just one queue but no effect so far on the limit I reached.
Does someone has an idea of the possible origin of the limitation?
FYI: I also defined my vi as time critical without success. My consumer was reduced to strict minimum for the test (clearing the queue).
(1,190 Views)
Accepted by topic author Jack587
  1. How did you determine the actual acq rate to be 1MB/s?
  2. Could you please share your code to take a look at?
  3. How does your setup perform with a shipping example as shown below?
Good to read about the bandwidth limitations,
https://www.ni.com/en-us/innovations/white-papers/12/streaming-architecture-of-the-industry-s-highest-performance-pxi.html
Santhosh
Soliton Technologies
(1,142 Views)
Thank you for your answer santo_13. I found out that i was having some backlogged data that was slowing down my process afterwards...
(1,103 Views)
