PXI
SH68-68-EPM vs
I noticed on a few schematics of our systems that the cables used for the PXI-6255 and PXI-6225 are different per channel.
Connector 0 has SH68-68-EPM
Connector 1 has SHC68-68
Shouldn't both be the same?
What is the proper cable that should be used?
What is the effect if we change cables?
Note that on some programs they do some insane software multiplication on mV signals (bad hardware designs). For example, a 30mV signal that is multiplied by 80.
(3,443 Views)
I guess the answer is on this datasheet, the SHC68-68 does not have shields between the analog and digital signals, the EPM has improved noise rejection.
Shielded Cables for 68-Pin Devices - http://sine.ni.com/nips/cds/view/p/lang/en/nid/11785
The EPM Series, feature separate digital and analog sections, a double-grounded shield, individually shielded analog outputs, individually shielded twisted pairs for all analog input, and twisted pairs for critical digital I/O.
Also, check these for the connection:
Dimensional Drawing for SHC68-68
https://www.ni.com/en/support/documentation/dimensional-drawings/model.shc68-68.html
Dimensional Drawing for SHC68-68-EPM
https://www.ni.com/en/support/documentation/dimensional-drawings/model.shc68-68-epm.html
https://www.ni.com/en/support/documentation/supplemental/17/main-page---daq-multifunction-i-o-cable-...
(3,394 Views)
Thanks niarena.
Apparently when we originally bought the system from NI, we requested a plug-and-play system with all the cards and cables, which they selected those cables for the card.
Would it be suggested to swap all SHC68-68 for the SHC68-68-EPM cables?
(3,384 Views)
It depends on the sensitivity of the circuit, it the signals do not need them, then, not, it is just a matter of how it was designed
(3,343 Views)
