PXI
Substitute cables for SHC68-68-EPM?
I have a PXI-6363.  The recommended cable is the SHC68-68-EPM.  I have one of those handy, but need 2.  I found a couple of unused cables laying around (SHC68-68-RMIO & SHC68-68-RDIO).  Can I use either of these as a substitute for an EPM cable?
(4,309 Views)
Accepted by JShan03062
I'm not convinced that you can just substitute them, and if they do work it would not be ideal. For one, the SHC68-68-EPM specifies it terminates in a 68 pin VHDCI offset, whereas the others are just VHDCI, but I haven't been able to find information on the difference. Beyond that, they don't list compatibility for X and M series for the RMIO or RDIO cables. While they're all 68 pin cables there are vast differences in wire grouping and shielding, and they're all optimized for different functionality/DAQ cards.
Eden K
Applications Engineer
(4,291 Views)
For future reference, we do not recommend the RDIO and RMIO cables for the PXIe-6363 due to their signal pairings and more.
You can check out other PXI-6363 options here: https://www.ni.com/en/support/documentation/cable-accessory-guide/daq-multifunction-i-o-cable-access...
And check out more about DAQ cables here: https://www.ni.com/en/support/documentation/cable-accessory-guide/daq-multifunction-i-o-cable-access...
Paul Davidson
Product Owner - ni.com Chat
(3,711 Views)
