02-21-2020 02:41 AM
Hello Everyone,
i am currently working on the 6683h Card( to be precise Timing Module for Synchronization).
Situation: I am able to follow up the ptp synchronization using 6683h module.... ie. GM-->Master-->Slave
Approach: i am trying to work on 802.1 AS Protocol (gptp) using same 6683h module.
Question: Is the card able to provide gptp(802.1 AS) synchronization, since gptp has some requirements and i am not sure if the card fulfills it. ?
if yes, could anyone suggest me a solution to above approach if the card is capable of 802.1 AS,
Looking forward for the Community Discussions and Interaction.
Thank You everyone in Advance.
Solved! Go to Solution.
		02-21-2020
		08:34 AM
 - last edited on
		08-29-2025
		02:40 PM
 by
			Content Cleaner
Hi there,
The 6683H doesn't support 802.1 AS natively. You may be able to use additional hardware to bridge the 6683H's 1558 to a TSN (802.1 AS network), though.
I found the following KB that speaks to this a little bit.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kKC4SAM&l=en-US
Here's some additional info for those interested:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019V0iSAE&l=en-US
https://www.ni.com/en/shop/compactdaq/choosing-a-compactdaq-synchronization-technology.html
02-24-2020 03:43 AM - edited 02-24-2020 03:46 AM
Thank You Captain_K, for sharing the Information. I will surely look into it....
Once again Thank You for your Kind Support and I hope to hear from you in further discussions as well.
02-24-2020 08:08 AM
Hi Captain_K,
Just Like PTP, is it possible to run gPTP on RT Linux without 6683h ie. By specifying an ethernet intereface as master(in Linux Terminal Window) further connected to slave sensor ?
Well in this case I am trying to avoid TSN !
Any Suggestions/ideas/Solutions/Approaches are welcome.
I thank You in Advance. 🙂
