07-14-2006 12:36 PM
07-17-2006 01:24 AM
Plz go through and do a check on these details
Are you feeding a Pure DC Voltage level?? or are you observing some fluctuations/noise in the voltage read by DAQ.
Is it a floating or ground referenced voltage source??
What Input mode ( your card has 3 Analog input modes, RSE, NRSE, Differential) are you reading the signal in?
and have you wired the signal correctly for that mode??
are you following the connection details mentioned in 'Connecting Signals' section of the DAQ card user manual??
07-17-2006 05:43 PM
