PXI
ballard mil-std-1553 LIBRARY FILES SUPPORT
HI, I i have inserted MIL-STD-1553 PCI card in slot and installed drivers for LX1553-5 .BTIdriver librarys given with installation drivers are labview 8.6 and labview 2010.But labview version in my pc is labview 2014.I have selected LABVIEW 2010 driver library zip file and included in user.lib in national instruments.
but labview vis not updating in vi library.they are showing blank vis with question mark as shown below.please tell the solution.
(2,882 Views)
Hi Sowmya92,
Can you post the readme of the driver? I'd like to see if there are installation instructions in there. There may be more to porting this to LabVIEW 2014 than just putting the BTIVI folder in the user.lib directory.
Just as an FYI, NI does partner with Ballard and their PXIe Omnibus II modules (1553 and 429), but we don't support the their PCI Omnibus (not II) modules. I believe the MIL-STD-1553 PCI card is their legacy Omnibus card. The driver for the PXIe modules that we do support should auto extract itselves to the instr.lib, not user.lib. I'm not sure if this is different for the PCI modules, but you may want to reach out to Ballard and see if they can help as well. They may have a more updated driver for this card as well.
(2,851 Views)
