PXI
comand power supply through GPIB
Hi I am Michele De Santis,
I am trying to command a elind 500 KL power supply through GPIB with a NI PXI. I can easily read the values of current and voltage of the instrument with the VISA read block in LabView environment. The problem presents when I want to use the write VISA block, in other words when I want to put a voltage and current values from my PXI. The instrument put itself, after I send the command, in CCM (current costant mode, before it was in VCM voltage costant mode) at 0 V and 0 A and from this moment on, I can't switch the status of the power supply unless I dont turn the instrument off. Anyone knows why?
Thanks!
(3,339 Views)
Hi Michele,
have you tryed to control yours Power Supply from another GPIB controller?
Cheers,
Matteo Brunella
Application Engineer
NI Italy
(3,325 Views)
