Hello every1,
am trying to build a program which reads a total of 52 Force Sensing Resistors FSR and perform a number of calculations on these readings. My initial program is just a prototype, which means the readings of the sensors are given. I put inserted 52 constants into the program with different numbers. I would like to know if there's a command in labview or a program which counts the total number of the constants which have a reading > 0.
I would really appreciate your help. Thank you
Safeya
