PXI
error during self calibration - PXI-4461
Carisa, thank you!
:),  Andrey
Message 21 of 26
(1,802 Views)
hi,
I'm sampling acceleration with a labview VI. a few days ago I noticed the DC of the signals are no longer zero centered.
when trying the self-calibrate the PXIe-4496 from the MAX i'm getting the same message (the self-test is working properly).
can I repair / calibrate without sending the board to NI?
Help would be highly appreciated,
Mor
Message 22 of 26
(1,741 Views)
Hi morb,
It does look like we need to send in the board for repair if this is experiencing the same issue that is referenced in the earlier part of the thread.
Jason D
Message 23 of 26
(1,716 Views)
Hello!
Sorry, after self-calibration PXI-4461 we have:
error -200719
What is mean?
Thank you, Andrey
Message 24 of 26
(1,640 Views)
Hi Andrey,
Being that this is an old fourm post, I would recommend creating a new post to get more visibility on your question. Including screenshots of the error you see would be helpful in the new post as well.
Thanks!
Message 25 of 26
(1,605 Views)
Called to NI engenier.....
Saying it is fuse on ao0 channel (ao - analog output).
And inviting to send card fo repair....not self -repair.
Thank to all!
Message 26 of 26
(1,580 Views)
