PXI
installation
I have followed the installation procedure for PXI 5404 from the starting guide. It shows present in my PXIe 1062Q chassis. However, i'm not seeing the soft control panel for it. The access LED with the card is also not lit.
Would you please help me to figure this out?
Thanks.
(2,859 Views)
To help troubleshoot this better, can you tell us how you are controlling this PXIe chassis? Do you have a controller or are you using a MXI card?
Claire C.
AppSW Staff Product Support Engineer
CLD|CTD
(2,836 Views)
I'm running this chassis using a PXIe-8105 embedded controller.
Thanks.
(2,833 Views)
Which version of NI-FGEN are running? You can find this by looking under "Software" in NI MAX.
Claire C.
CLD|CTD
(2,823 Views)
The version is 18.1. I looked at it from DVD kit. Whenever i'm trying to see it from software tab, it shows following error
(2,812 Views)
The article that this is referring to is the one below, I believe:
How to Fix or Reset the NI MAX Database File
Can you try to reset this and let me know what is the result?
Claire C.
CLD|CTD
(2,801 Views)
Thanks! Now, it works fine.
(2,795 Views)
