PXI
migration to LV 2018
Dear NI Communty,
We Have a Real time application running under LV 2016, now we want to migrate to LV 2018, first I tried to open our application using LV 2018, I got some errors but I was able to fix them so at the end all the Vis were not showing any errors, and I was able to run the Host application and the RT PXI application without any issue.
The problem appeared when I deployed the RT executable inside the PXI target, the RT PXI application was not running, I modified within the Build specification to enable debugging, and I tried to debug the application using the “Debug Application or Shared Library” by entering the IP address, the RT application was broken but I couldn’t see the errors, but using the View tab I could see the errors.
When I try to fix the errors, I can’t see how to fix them since inside the block diagrams there is nothing broken. I tried also to perform a mass compile but I couldn’t fix the issues detected since as I said there is nothing to fix. I have tried also to create another project with LV 2018 and import everything (DLLs, Vis,…) but at the end I got the same results.
Could you please help us regarding this issue ?
I have attached the error log file of the PXI.
Thank You,
Best Regards,
(2,408 Views)
Did you update the NI software and firmware on the PXI controller to the 2018 versions through MAX?
(2,377 Views)
Yes of course ! this was the first thing i did.
(2,335 Views)
