PXI
minimum analog voltage
What is the minimum analog voltage signal that can be generated from an DAQ device (eg : USB 4431 ) ?
Can analog voltage signal of order of micro volts (e.g 10-100micro ) be generated with any analog output card?
(5,145 Views)
What kind of accuracy do you need?  The USB-4431 has an AO, but the typical DC offset is 700uV, 2mV max.  So I wouldn't count on it setting to 10-100uV.
GCentral
(5,143 Views)
