09-18-2014 04:14 AM
hj. help me
my laptop don't install labview 2012 can ping with pxie 8135 but labview installed on my laptop can't ping with pxie 8135. i don't understand
Solved! Go to Solution.
09-18-2014 06:22 PM
Hi ffefef,
Would you mind explaining in more detail the issue you're having?
09-18-2014 10:51 PM
hj. thank rep
before i install labview 21012, I ping from your computer to have an IP address of PXIe is 169.254.100.112 (manufacturer's default), on my computer ip address is 169.254.100.111 (subnet mask: 255.25. 0.0), the two machines connected normal.
when i installed labview 2012 with the same configuration, it does not ping. On cmd of my computer saying "reply from 169 254 100 111: Destination host unreachale"
09-19-2014 08:45 AM
Hi ffefef,
Let me just ask a few more questions:
1. Did you install LabVIEW 2012 onto your PC, or onto the PXIe-8135 controller?
2. Is the PXIe-8135 running Windows or a Real-Time operating system?
If it's a real-time operating system, you may want to take a look at this white paper that outlines some general troubleshooting steps for real-time PXI controllers: http://www.ni.com/white-paper/5403/en/
