PXI
pxie 8135 can't ping pc when labview installed
hj. help me
my laptop don't install labview 2012  can ping with pxie 8135 but labview installed on my laptop can't ping with pxie 8135. i don't understand
(6,291 Views)
Accepted by linh25
Hi ffefef,
Would you mind explaining in more detail the issue you're having?
Rick C.
(6,271 Views)
Accepted by linh25
hj. thank rep
before i install labview 21012, I ping from your computer to have an IP address of PXIe is 169.254.100.112 (manufacturer's default), on my computer ip address is 169.254.100.111 (subnet mask: 255.25. 0.0), the two machines connected normal.
when i installed labview 2012 with the same configuration, it does not ping.  On cmd of my computer saying "reply from 169 254 100 111: Destination host unreachale"
Smiley Sad
(6,264 Views)
Hi ffefef,
Let me just ask a few more questions:
1. Did you install LabVIEW 2012 onto your PC, or onto the PXIe-8135 controller?
2. Is the PXIe-8135 running Windows or a Real-Time operating system?
If it's a real-time operating system, you may want to take a look at this white paper that outlines some general troubleshooting steps for real-time PXI controllers: http://www.ni.com/white-paper/5403/en/
Rick C.
(6,245 Views)
