PXI
simulated devices
Hello, I was using measurement and automation to simulate a new device. I could not find NI PXI-5421 which is an AWG in the list. How do I add that to the list?
Thank you.
(4,733 Views)
I believe that you will find this KB helpful in simulating your 5421.
http://digital.ni.com/public.nsf/allkb/07A1DC2A64B4F0A38625729A00065771?OpenDocument
Marcus
Marcus M.
PXI Product Support Engineer
(4,719 Views)
Is doing this the same as using the measurement and automation ex to simulate a device?Thank you.
(4,716 Views)
Doing this will allow you to simulate the device from within LabVIEW.  It will not give you access to this piece of hardware as if it was in MAX however.
Marcus
Marcus M.
(4,709 Views)
Is there a way to add the NI-5421 to the simulated NI-DAQmx device or Modular Instrument menu in the measurement and automation explorer?
Thank you.
(4,706 Views)
You unfortunately cannot add the NI-5421 to the simulated NI-DAQmx menu.  You can only simulate this device in LV.
Marcus
Marcus M.
(4,696 Views)
