PXI
speeding up PXIe-4138 measurements
I have modified an example VI to source voltage and continuously measure current from my PXIe-4138. However, it could only take about 4 measurements per second, which is not at the speed that I need. how can I make it measure faster. there are 2 channels because a I am sourcing another voltage simultaneously that is supposed to affect the current measurements.Capture.PNG
(1,692 Views)
Try stay in loop only measure VI and initialization out of loop.
(1,628 Views)
I want to be able to change the applied voltage manually and observe the change dynamically.
(1,615 Views)
Accepted by Walid20
For example. Is it suitable for solving the problem?
(1,611 Views)
Thank you.
It worked for 2 channels as well
(1,602 Views)
