PXI
synchronisation de la carte d'acquisition NI PXIe 6356
I am in the process of acquiring data with the NI PXIe 6356 card. The signal generation is done with the tektronix function generator. i use a multisine signal that i sample at a frequency of 100hz and the signal in question is 4000points. however, there is a synchronisation problem between the two systems. It should be noted that the card is fixed in the NI PXIe 1066 DC chassis. for synchronisation i use the chassis clock reference which is 10Mhz. are there any other specific settings that i need to make? because even though the connection has been made and the external clock has been activated on the generator, the same problem persists.
La carte utilisée et le chassis sont représenté ci-dessus
(339 Views)
Please refrain from creating duplicate posts, typically the same active users are responding in almost all relevant boards.
https://forums.ni.com/t5/Counter-Timer/Synchronization-of-NPXI-1066DC-chassis-and-function-generator...
Santhosh
Soliton Technologies
(317 Views)
Merci
(313 Views)
