PXI
synchronizing SMU (PXIE4139) and NI RFSA( PXIE 5840)
Hello All
I use PXIE 1085 and I want to synchronize the SMU(PXIE 4139) with NI RFSA (PXIE 5840). how can i do this?
I used the way for the synchronizing the SMU and PXIE 5840 (I attached its picture), however in this method I need a VI which gives the NI DCPOWER GET SESSION REFERENCE, and i cant find it in the NI DCPOWER palette.
(3,519 Views)
Hi yashar93,
You could try using NI-TClk to allow multiple instruments to simultaneously respond to triggers, to align Sample Clocks on multiple instruments, and/or to simultaneously start multiple instruments. More information can be found here:
http://zone.ni.com/reference/en-XX/help/370956M-01/nitclk/nitclk_overview/
(3,472 Views)
"Hello Kelly_ Chan
yes i wanted to use NI TCLK to synchronize them, but if i want to use NI TCLK first of all i should enable the NI TCLK for NI DCPOWER  and in this link , they mentioned a method for this aim. but the problem is here, i cant find solution explorer in LABVIEW to do the mentioned steps.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019SOrSAM
 my problem is here "  In your project, add a reference to the NationalInstruments.ModularInstruments.Common assembly. Right-click References in Solution Explorer, select Add Reference"
since i cant find solution explorer.
(3,465 Views)
"Hello Kelly_ Chan
(3,463 Views)
Accepted by yashar93
i found the answer. if you want to synchronizing the SMU with RFSA (PXIE 5840) should use the back plane and send trigger from PXIE 5840  to SMU, to start trigger
(3,378 Views)
