 Rakesh9490
			Rakesh9490
			12-03-2015 02:51 AM
Hi... I am simulating a single phase H bridge inverter. When i get the ouput to be seen in labview from multisim through the HSBC connector, I am not getting the exact one that is obtained in oscilloscope.. I have attached the files.. Any help is appreciated..
12-03-2015 10:43 AM
Can you tell us more about what you seeing and what you expect? I see signals that are toggling with 50% duty cycle at 50 Hz between a positive and negative voltage.
12-03-2015 10:55 AM
Hi... I am getting a two level inveter output in multisim scope. But when the same implemented in cosim, I am only getting the positive voltage and not the negative voltage at the output...
12-03-2015 11:04 AM
I'm seeing a negative. Is yours going to ground, or just near ground.
12-03-2015 11:04 AM
.png)
This is the correct output in multism with both positive and negative voltages..
But see below in labview, only positive output..
.png)
12-03-2015 11:17 AM
This is the image of multisim with cosim.png)
12-04-2015 10:45 AM
Well your currents are going negative which means that the voltage should go negative. What if you put a connector on the negative side of the variable resistor and look at the difference?
12-04-2015 11:53 AM
Still the same thing. I am only getting the positive voltage.
12-04-2015 01:35 PM
The schematic you uploaded had a static resistor. Any chance you could move back to that to tell the difference?
12-05-2015 12:56 AM
I tried... But that doesnt work... I suspect this is a bug to be fixed!
