Power Electronics Development Center
Measuring single phase ac voltage in cosim
Hi... I am simulating a single phase H bridge inverter. When i get the ouput to be seen in labview from multisim through the HSBC connector, I am not getting the exact one that is obtained in oscilloscope.. I have attached the files.. Any help is appreciated..
Message 1 of 18
(7,859 Views)
Can you tell us more about what you seeing and what you expect?  I see signals that are toggling with 50% duty cycle at 50 Hz between a positive and negative voltage.
Brian K.
Message 2 of 18
(6,301 Views)
Hi... I am getting a two level inveter output in multisim scope. But when the same implemented in cosim, I am only getting the positive voltage and not the negative voltage at the output...
Message 3 of 18
(6,301 Views)
I'm seeing a negative.  Is yours going to ground, or just near ground.
Brian K.
Message 4 of 18
(6,301 Views)
This is the correct output in multism with both positive and negative voltages..
But see below in labview,  only positive output..
Message 5 of 18
(6,301 Views)
Message 6 of 18
(6,301 Views)
Well your currents are going negative which means that the voltage should go negative.  What if you put a connector on the negative side of the variable resistor and look at the difference?
Brian K.
Message 7 of 18
(6,301 Views)
Still the same thing. I am only getting the positive voltage.
Message 8 of 18
(6,301 Views)
The schematic you uploaded had a static resistor.  Any chance you could move back to that to tell the difference?
Brian K.
Message 9 of 18
(6,301 Views)
I tried... But that doesnt work... I suspect this is a bug to be fixed!
Message 10 of 18
(6,301 Views)
