03-07-2016 11:52 AM
fairlyFunctional wrote:
Sometimes it's a WAT instead of a WS. For the common ones I've written single-key shortcuts. Anyone else had this trouble? Any appeal for single-key shortcuts?
Oh yeah I've seen this often. I usually just chalk it up to me being faster than my computer (or rather faster than QD). So I'll CTRL+Z and try again. It happens to me a couple times a day.
As for the single letter shortcut, that is up to you and you can add them. But as a global setting for all LabVIEW users I'm sure getting an agreement would be difficult. Should "s" be string length? String Constant? Empty String?
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
03-07-2016 01:38 PM
I agree with Brian, I figured it would be difficult for us to coalesce around a common item to drop with a single letter. And you are free to modify the shortcuts to be single letter for any objects you wish.
There is one exception, though... I made 'x' be the shortcut for the Multiply function. ![]()
03-10-2016 08:55 AM
You know what, now that I've slept on it, I think one letter shortcuts could be used for constants. p - Path, s - String, t - True, f - False, v - Variant, w - Waveform, n - Numeric, d - Double, a - Array, c - Cluster. I'm not saying it should be this way, but if there were one letter designations I could think of no better things for them to collectively represent then constants.
03-11-2016 05:00 PM
Along the lines of constant shortcuts ending in 'c', there seem to be 'loose' rules coalescing out of the list. For example, all the file I/O shortcuts end in 'f', most of the structure shortcuts end in 's' (should 'evstr' just be 'evs'?). I can see others that could be added, for example booleans could end in 'b':
ab - And
vb - Or (to follow the 'vae' example)
eb - Exclusinve Or
nb - Not (I realize this isn't fully left handed but I don't think hitting the 'n' key left handed is an unreasonable compromise.)
nab - Nand
nvb - Nor
neb - Not Exclusive Or
Does it make shortcuts easier to remember if there are guidelines or rules to define categories? It would have to be a short list. And a loose interpretation because of the shortcuts that don't fit (like 'tsc' which isn't a constant).
(And in my example I'm ignoring the question of whether or not 'ab' is a useful shortcut, I could probably type 'and', even with just my left hand, as fast as remenbering 'ab' is the shortcut. At least until the muscle memory develops.)
