Quick Drop Enthusiasts
Move and Size QD Plugin
Could this be made available for LV 2013?
Message 11 of 18
(2,553 Views)
Wish I could get this to work on control panels.  Is it possible or does QD only with with VIs?
-John
Certified LabVIEW Architect
Message 12 of 18
(2,553 Views)
I only have 2011 and 2014 installed.  Perhaps someone can downgrade it for you.
-John
Message 13 of 18
(2,553 Views)
Quick Drop works with all VI types, including Control VIs. The reason this plugin doesn't work is that the MoveObjects method in scripting, which is called by this plugin, returns error 1035 on control VIs. I don't know why that is, seems like it should work fine.
Message 14 of 18
(2,553 Views)
So, is that a bug or a 'feature'?  If bug, can you submit a CAR for me?
-John
Message 15 of 18
(2,553 Views)
Looks like bug.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 16 of 18
(2,553 Views)
It might be cool to add option to change this one_grid_size distance into eg. one_grid_size*multiplicator when shift pressed.
Michał Bieńkowski
CLA, CTA, CPI
Message 17 of 18
(2,553 Views)
Concerning a possible workaround for error 1035 on "Move Objects" when applied to Control VIs
First: As I can't look into the VIs with my latest LV-installation of 2013, my proposal might be nonsense.
Why not iterate over all controls in question with the Control property "Position" instead of using the above mentioned VI method? I illustrate my idea in the attached image.
Hope this helps
Message 18 of 18
(2,553 Views)
