RF Measurement Devices
Change GPS sampling rate or IQ rate?
If you have modulation toolkit, the one in the modulation toolkit does work with only complex inputs.
Sastry Vadlamani
RF Principal Software Engineer
Aerospace and Defence BU
Certified LabVIEW Architect
Message 11 of 14
(4,450 Views)
Sastry,
 Which vi are you referring to in the Modulation Toolkit? I've looked at the MT Fractional Resample.vi and that uses a waveform input.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 12 of 14
(4,436 Views)
Hi Sastry,
I'm using the one in Signal Processing ...
Arpi
Message 13 of 14
(4,430 Views)
Hi GovBob,
I am talking about the MT Fractional Resample in Modulation Toolkit. Yes, it does take in waveform input. It is rather in the form of a complex cluster. The cluster elements are t0, dt and Y where Y is the complex data sampled at the input rate of R=1/dt.
Sastry
Sastry Vadlamani
Message 14 of 14
(4,422 Views)
