RF Measurement Devices
MT Convolutional Decode VI
Sorry , I try to use MT Convolutional Decode VI but don't have  output
(3,788 Views)
Accepted by OATTelecom
Well. You are using rate 1/2 with a traceback length of 15. That means the length of the input data (which is coded data) to the decoder should be (>15)*2  that is, >=32.
I see in the image that you are providing <32 length data and hence the output is empty. Make it >=32 and you will start seeing the output data.
Sastry Vadlamani
RF Principal Software Engineer
Aerospace and Defence BU
Certified LabVIEW Architect
(3,764 Views)
