RF Measurement Devices
Missing Sub-VI Poly-VI MSO
Hey, hope someone can help me...
i tryed to use a VI from NI:
https://forums.ni.com/t5/Example-Code/NI-VirtualBench-Erfassen-analoger-und-digitaler-Signale-mit-de...
but i got numerous error message after labview tried to open it:
Poly-VI 'MSO Configure Analog Edge Trigger.vi': SubVI is missing.
And a lot of more from this type e.g.: MSO Run.vi
The problem is i cant find those MSO subvi´s via google or here.
Or are they not downloadable for free?
Thanks a lot!
(4,219 Views)
Accepted by Gregory88
You need to install NI-Virtualbench.  Here's a link to the latest version. https://www.ni.com/en/support/downloads/drivers/download.virtualbench-software.html
John Fenner
RF Software Engineer
(4,204 Views)
thanks john, now i can open it... but dont use it because i dont have the required hardware. i thought i can use it with my NI scb68a.
can you tell my how i can "freeze" or pause continously measured real time signals from produced with a Mems sensor?
i tried to create my own oszi and i have the idea to do it with a trigger, but always when pushing the trigger, my signal gets lost!?!?!? o.O
(4,180 Views)
Sorry. I'm afraid I was just answering the easy question regarding the broken VI. I won't be of much use to you. You might try posting your question in the VirtualBench forum. https://forums.ni.com/t5/VirtualBench/bd-p/340
John Fenner
(4,168 Views)
