RF Measurement Devices
PDA Bluetooth using pocket PC win CE XP version 2
I wrote a bluetooth aplication & tested it on Win CE 2003 based devices , installed Widcomm drivers , it worked perfectlly.
Afterwards I tried installing it on win CE 2003 ver 2 based devices (several diffrent ones) , the widcomm driver was not compatible with operating system.
where can I find a matching driver?
thank you
(8,914 Views)
It looks like Widcomm was bought out by another company, and has moved support to that website.  I found this doucment which gives information about the latest  BTW-CE driver which is required to run Bluetooth on the LabVIEW PDA Module.  Check out those links and let us know if they were helpful.  I'm not exactly sure on Widcomm's support for newer operating systems, but you for sure need a BTW-CE v 1.4 driver or later to use the PDA module.  Which versions of the driver have you installed, and what is the exact error that you are getting?
Thanks for posting, please let me know if we can assist any further.
Travis M
LabVIEW R&D
(8,899 Views)
