What-ho Wire Wrestlers.
I had two other options for this article
Or alternatively I could leave the ODS API half-cooked and I'm not in the mood to grizzle. So instead I'm going to talk about ODTs
ODTs are the output of Open Document Word Processors, including newer versions of Microsoft Word, Open-Office Writer and LibreOffice Writer.
Before I plough in and do the hard work I thought it might be good to request some input from other users.
Here's one use-case that would be marvellous for me.
Here I have my bug reporting tool, when I press commit I would like it to generate an issue report document, with all the details filled in for me. This would be way better than my current "Issue Saved" dialog confirmation.
Using a similar model to the one I employed for the spreadsheet I could load a template and update it.
Luckily both Word and Openoffice offer bookmarking facilities. We could organise our template with various bookmarks and then offer methods to insert things at the book mark point. In ODS I have fathomed tables, Images are just links and the images go into a directory called ..\Configurations2\images\Bitmaps, text is a direct replacement.
Main page data goes in content.xml
Header and Footer info goes into styles.xml so I would need to search that for bookmarks too.
The bookmark tags come in two flavours.
<text:bookmark text:name="headerbookmark"/> <--- this is just a single place point and your insertion goes either at the end or the beginning of this tag.
<text:bookmark-start text:name="my2ndbookmark"/>ddd<text:bookmark-end text:name="my2ndbookmark"/> <--- this is a range of text that should be replaced by whatever is inserted.
The only additional facility that I can think that will be useful is the ability to duplicate pages.
Here's the updated (version D1:01) example program screen
This demonstrates both ODS and ODT generation.
Here's another instance where I could use this type of functionality.
I generate a new document number for a project using this little utility, it would be splendid if it actually generated the document all numbered and dated.
Is there any other use-cases that would be handy?
Leave words of wisdom in the comments please.
Much Love
Steve
04-May-2016 added ODF toolkit, this purely replaces/insert text into a template and saves the template, as a bonus there's a bit that then converts the ODT file to a PDF if you have LibreOffice (probably works with OpenOffice too). Created file works with Word too. Questions and use cases into the comments please. ODTExample.vi shows usage. Video to follow...
06-May-2016 Made the text entered XML safe (as far as I know) for ODS and ODT
19-05-2016 D1:01 added version numbering and prettied up the example, tested with provided templates and works OK. Used LibreOffice 5 for the pdf printing
08-06-2016 D1:02 ODTGetBookmarks removed table of contents "RefHeadings" bookmarks LV2014
Steve
Opportunity to learn from experienced developers / entrepeneurs (Fab,Joerg and Brian amongst them):
DSH Pragmatic Software Development Workshop
