Hello Disease Avoiders (hopefully),
I hope you are keeping fit both physically and mentally.
My DSH friends and I decided to announce some on-line events to coincide with NIWeek (17th May to 21st May) and the idea has blossomed somewhat. We now have quite a few volunteers and a fantastic hashtag/name courtesy of Chris Stryker...........#VIWeek.
NEWS ---> Re-certification by points - 10 pts for attending VIWeek and 20 pts for presenting...isn't that nice of NI!
So this page will be our VIWeek agenda but check out the LabVIEWwiki and the excellent page by Derrick Bommarito, it's very much more user friendly.
https://labviewwiki.org/wiki/Home
Discord Channel thanks to Michal Radziwon
We can fill the slots on a first-come first served basis. I think people can host their own events (I use webex and it costs £15 a month) and it works fine.
I'll put some other tips at the end.
Agenda - Keep Checking Back
Contact the Session Host to get a link
Sunday 17th May
| 7-8am PDT, 9-10am CDT, 3-4pm BST, 4-5pm CEST |
 GCentral: State of the Union and Rolling Up Your Sleeves Chris Cilino GCentral is a non profit organization founded in late 2019. The vision: a LabVIEW community empowered to make the best version of itself. The mission: reduce/remove barriers to collaboration. In this presentation, we'll introduce you to GCentral and give a progress update. And we'll show you how we can all work together to make GCentral a reality.  |
 9-10 PDT, 11-12noon CDT, 5-6pm BST, 6-7pm CEST Do the survey suckers - here  |
 LabVIEW FPGA for high throughput applications Terry Stratoudakis
 Microsoft Teams link: Register /Join  |
| 11-12 PDT, 1-2pm CDT, 7-8pm BST, 8-9pm CEST |
 Functional programming inspired object-oriented template in LabVIEW + SOLID Piotr Kruczkowski
Monday 18th May
 DSH #VIWeek Pragmatic SW Engineering email hello@dsh-workshops.com  |
| 9-10 PDT, 11-12noon CDT, 5-6pm BST, 6-7pm CEST |
 Philosophy of Coding - How to be a CraftsPerson. Sam Taggart A discussion of how what we value and the way we think about the process of developing software affects the end result. No LabVIEW code, just a high level discussion of software engineering. I've got a short presentation on our values at SAS and how we approach software development. I'll give that and I'd like to get some feedback. Then I'd like to have a discussion and ask the audience some questions like, what software qualities are important to you? What processes do you think are critical to ensuring software quality? What quality is most important in a junior engineer? How can we do a better job of training junior engineers?  |
 Confessions of a Retired Superhero Matt Pollock Crazy projects demand crazy solutions. Crazy solutions create crazy bugs. Come learn from spectacular failures (or near failures) that have threatened to torpedo other projects so yours will be safe from heroics.
Tuesday 19th May
 Proper way to communicate over serial. Tim Robinson Too many users look to the Simple Serial Write Read example in LabVIEW and then struggle to achieve solid, robust communication with their instrument. This is because the example does not properly discuss or handle any of the real-world communication schemes instruments use. At this session, explore these schemes and learn how to handle each case.
 Raspberry Pi / LABVIEW Community Edition and Sensors Sam will demonstrate/show how to get started programming the Raspberry Pi using the LabVIEW 2020 Community Edition with a live/practical demo. He'll then expand this to show off his open-source library of drivers for a range of off-the-shelf sensors/hats so you can connect your Raspberry Pi to the physical world. Webex Link:Register /Join sam@mediamongrels.com  |
 Linx Toolkit & Raspberry Pi for Intermediate Robotics Derrick Bommarito I'll be demonstrating how I've used the updated Linx Toolkit for LabVIEW Community Edition to develop remote control and autonomous rovers using the Raspberry Pi along with a handful of sensors. We'll take a look at the high level architecture of the software along with the open source libraries I'm developing that target autonomous robotics projects. We'll also discuss how you can accomplish better performance for more demanding projects by developing custom firmware for arduino clones instead of using the Linx toolkit to interface to microcontrollers.
| 1-2pm PDT, 3-5pm CDT, 9-10pm BST, 10-11pm CEST |
 Build Flexible FPGA-Based Systems with LabVIEW FPGA Advanced Sessions Cyril Gambini Creating an FPGA-based acquisition and control system is challenging if the hardware target changes and the bitfiles to load are completely different from one target to the next. Learn how you can handle completely different FPGA personalities within the same application using LabVIEW FPGA Advanced Session Resources. At this session, explore a VeriStand distributed DAQ system featuring multiple CompactRIO devices configured differently based on the test to perform (analyzing the electrical and mechanical behaviors of alternators) and the test’s measurement requirements (currently more than 20 different configurations across four target references). Email:cgambini@neosoft.ca Teams Link Join  |
| 2-3pm PDT, 4-5pm CDT, 10-11pm BST, 11-12pm CEST |
 8 Reasons for encapsulating your next device driver inside a DQMH module Christopher Farmer Do you hate it when software throws an awful error if a device is not connected, and it just stops or crashes as a result? Do you have multiple instances of the same device that you need to manage? Do you find that your applications get so cluttered with code specific to managing devices? Do you like to see what a device is up to “under the hood” whilst you run an automated sequence? If you’re facing any of these challenges, then we’re confident this presentation will help you! Using a DQMH module to encapsulate your next device driver will eliminate these issues. Register below to learn how.  |
Wednesday 20th May
 Fab, Joerg email hello@dsh-workshops.com  |
 'Efficient Programming in LabVIEW' Tom McQuillan  |
| 10-11am PDT, 12-1pm CDT, 6-7pm BST, 7-8pm CEST |
 Graphical programming beyond G - Use case of LabVIEW integration with Node-RED Michal Radziwon Dataflow programming is not only about G and LabVIEW! There is more and more of other platforms that uses graphical programming and one of them is Node-RED. Node-RED is a programming tool build to ease connecting and automating IoT enabled devices, APIs, and web-services. I will show a use case of integrating LabVIEW with Node-RED using MQTT server - all running on a Raspberry Pi.  |
 Using a Message Broker with DQMH Actors for High Speed/Throughput Data logging Chris Roebuck and Becky Linton Tasked with creating a hardware agnostic, highly configurable, high-throughput data logger for ADAS applications we implemented the Mediator pattern using multiple modified-DQMH actors with a message broker. In this session we will review the requirements, high level design objectives and review the solution and take a deeper dive in to some of the specific technologies used such as malleable VIs, eDVRs and Message Brokers. b.linton@konrad-technologies.com,c.roebuck@konrad-technologies.co.uk Teams Link :  |
 6-7pm PDT, 8-9pm CDT (Thursday 21 May 9-10am SGT, 11am-12pm AEST)  |
Thursday 21st May
 CEF (configuration editor framework) Sreejith Sreenivasan and Vikas Koujalagi Configuration files are commonly used to specify application settings and hardware configuration. Manual editing of some of the complex configuration files of hardware systems or applications are often error prone. Shipping a configuration editor can ease the pain but development overheads may outweigh the benefits. Configuration Editor Framework (CEF) from NI Systems Engineering is a versatile framework allowing rapid development of such editors. Development generally take hours instead of days or weeks. This presentation delves in to the features and walks through an example which saves the files in JSON format. MS Teams Meeting Link: https://bit.ly/VIWEEK_NICEF  |
 Using the new TLS/SSL functions in LabVIEW 2020 Sam will go through the newly added SSL/TLS functions in LabVIEW 2020 which enables secure TCP/IP communications in LabVIEW. This session should provide enough information to be able to implement secure TCP/IP communications in your own applications and learn why you should. He'll also demonstrate an update to his WebSockets library that enables secure WebSockets (wss://) support - a highly requested feature now possible with LabVIEW 2020. Webex Link: Register /Join sam@mediamongrels.com  |
 DSH Soft Skills for Software Engineers Discussion Steve and anyone else who wants to join It won't be the presentation I intended to do, more of a chat really. email hello@dsh-workshops.com  |
Friday 22nd May
 AristosQ suggests you check this vid out as an intro before this session - https://www.youtube.com/watch?v=gQU3eM0yLMk&feature=youtu.be or https://t.co/XUZKvffDUM?amp=1
 #VIWeek – Open Your Instruments With A G Interfaces HAL In LV2020 (No Lever Tool Required!!) Jonathan Hird (Jono) The recent release of LV2020 Community edition has opened up the new capability of “Interfaces” into the LVOOP world. I for one am incredibly excited about what this means specifically for Hardware Abstraction Layers. After some initial trudging through the mud and not quite seeing the value in interfaces for my specific needs for a HAL, I decided to scrap what I had, start from scratch and work logically to put together an example of a “Real World” HAL application. In this session we will briefly cover the Why, What and How of HALs and how interfaces may help along with some sample code which will be uploaded for community use as a good starting point.  |
 The Core Framework. Denis Stavila It's something that I built on top of the Actor Framework and aims at solving several shortcomings that I believe AF has ... plus a lot of tweaks and built-in functionality to make the life of a developer much easier:
 I started working on this framework basically the moment I faced my first project with AF ... I would like to show you what problems I encountered, how I attempted to solve them and what I wanted to achieve with it. Teams Link : Join  |
 Mock Object Framework Sam Taggart I will present an open source tool for creating Mock objects and show how to use them in tests. It will be an informal kind of code review thing. I might put together a few slides on what Mock Objects are so we are all on the same page. After that I will just start with defining the problem and then how I came up with the solution. We will spend a lot of time just looking at the code.
Saturday 23rd May
 Fast and Simple Unit Testing with Caraya 1.0 Francois Normandin, Jim Kring Almost everyone writes code to test their code. Caraya, a unit test framework for LabVIEW, makes it simple to turn those test VIs into unit tests that can be reused throughout the life of the project. With a focus on ease of use and lightning fast execution time, Caraya allows you to write and run tests without adding much overhead to your development work. Come see how you can create and run a test in under a minute, run all the tests in your project with a simple QuickDrop shortcut, and integrate your tests into a fully-automated build and deploy process. You’ll also learn about advanced features like running tests on real-time targets, creating custom test report formats, and more!  |
Contact me for changing the agenda, it's only my first guess and I'm missing all the eastern time-zones. TBH anything goes.
Tips for Hosting Events (based on my tiny amount of experience)
Have a moderator to field questions in chat, that way you only need keep 2 microphones open.
Kill non-presenters mics and screens when you are presenting, open up for discussions.
Tell people the rules before you start.
Don't spend ages preparing, free-form works fine in this environment. Scripted presentations come across as being a bit flat and dull IMO.
Switch off desktop icons (believe it or not I didn't know you could do this until Fab told me)
Use the hashtag #VIWeek
Any other tips people can think of?
Hopefully this will keep us amused in May
Lots of Love
Steve
Opportunity to learn from experienced developers / entrepeneurs (Fab,Joerg and Brian amongst them):
DSH Pragmatic Software Development Workshop
