Aurora on Artix GTP on sbRIO-9628 wired to RMVC connector
We would like to connect Artix GTP Transceivers (6.6 Gb/s Max Rate) to a custom board with SFP+ cages over RMC connector on the sbRIO-9628 board.
The current unknowns are:
- Are GTP signals wired to the RMC connector?
- Is GTP clock provided on the sbRIO-9628 board or should also be wired over RMC?
- Would it be possible to use the Xilinx Aurora IP (which is supported on Artix) with NI FPGA software tools (
LabVIEW FPGA).
Mitja
(1,099 Views)
I also have this question. Did you make any progress here? My plan B is to make a support request.
(971 Views)
