Building Dll for labVIEW RT gives errors
Hi All
Does building dll for labVIEW RT using CVI require labview runtime engine to be installed?
becuase i get some errors of unsatisfied referances to some library while building the dll with target selceted to "labVIEW real time only".
Regards
Arun
(3,515 Views)
Hello Arun, You don't need to have LabVIEW Run Time installed on your machine. Please check the link below to see the function that are supported by exporting the LabWindows/CVI LabVIEW RT Engine http://digital.ni.com/public.nsf/websearch/D3EFE7C6F073384886256FDD005FBCDA?OpenDocument Ame G. National Instruments
(3,506 Views)
Hi Ame
thanx  for the reply, am using the RS 232 functions in my dll, i guess this is natively not supported in the "cvi_lvrt.dll". Is there any way else i can create this
thanx for the reply
(3,493 Views)
