Can not find RT module in installation list for LV2009
Updating from 8.6.1 to LabVIEW 2009, August release.  LabVIEW 9.0 and most modules installed well.  I can not find cRIO RT module in the install list.  MAX reports that I have NI-RIO 3.0.0 w/SE support installed on the target, but the LV real time 9.0 option is missing LV RT 1.0.0.3, VxW 6.0, LV RT 9.0, LV RT VxW 9.0 and Base System 9.0.  When I pick the LV RT Deployment Option, it fails install.
(4,607 Views)
What version of NI-RIO are you using? If you haven't do so, install the latest version of NI-RIO. And, if you have, I would recommend reinstalling it.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,604 Views)
Version 3.0.0 of NI-RIO is installed and runs well under 8.6.1, but will not even connect with 9.0.  As I wait for the downloader to finish, it would have been nice if it was on one of the six DVDs that were in the box..., I will let you know how it turns out.
(4,597 Views)
Well, if you look at the Description of NI-RIO 3.0 (click on the link that I have mentioned above and choose that driver), you will notice that 3.0 doesn't support 2009. You will NEED to install the latest driver; it should be there on the Driver CD that you got with the pack.
Adnan Zafar
(4,591 Views)
I agree, and thanks for the tip to look on the driver disk, the 3.2.0 version was there.  The downloader stalled while I was installing it, but I am still going to be missing the host side RT development piece for the cRIO-9012 controller, ie., the cRIO RT clock icon doesn't show up on the start screen with the FPGA chip and embedded ARM board icons.  There is no R-T project or R-T.vi selection in the create new list either.  Maybe this is why it wouldn't pick up the driver the first time I tried to install.
(4,581 Views)
You need to install the RT Module for LV 2009. That should be included in the disks as well. The order always is: LabVIEW -> Modules -> Drivers.
Adnan Zafar
(4,575 Views)
Accepted by Sculptor
Yes, but just to be clear, the RT module would not install, so I was looking for a seperate RT module for the cRIO because the installation instructions were referring to one under an embedded folder.
The real problem, solved now, is the RT module would not install until I manually uninstalled the old NI Serial and then installed the new one with LabVIEW 2009.  During the first attempt to install LabVIEW 2009, the package configuator detected the old NI Serial and told me that it could not install the new NI Serial until I uninstalled the old, but gave me the option to defer this step, which I did.
Thank you for your help.
(4,553 Views)
