CompactRIO configuration
Hi Zach-H
Message 11 of 38
(3,192 Views)
This still depends on how you plan on using the FPGA.
Like I mentioned in my last message "There are some special steps you'll need to go through to use the 9870 in scan interface mode as described in the help here."
If that's the case you go with, yes you will need to add that VI to the project underneath the cRIO controller. Make sure the COM port in the VI you posted is set to the correct port address for the 9870 after you follow those instruction to set it up.
If you need more information for how to set up your project/Real-Time application I recommend going through the Getting started with the LabVIEW Real-Time Module manual.
CLD Certified
Message 12 of 38
(3,186 Views)
hi Zach-H
In the MAX , underneath my cRIO softwares i see "NI serial RT 3.6.0" .
is it other softwares to install for NI 9870 ?
regards
Message 13 of 38
(3,179 Views)
It still depends on how you plan on using the FPGA. (Scan Interface or FPGA Module)
If you're in scan interface, follow the help document that I posted for you and install the scan engine support for 9870.
If you're planning on using the FPGA module you should check out the help documentation on how to use it here
CLD Certified
Message 14 of 38
(3,163 Views)
Hi Zach-H
I want to use the NI 9870 with FPGA module.
The example of NI 9870 which is in LV, I have already used it in my LV project.
Now I want to restore it in the examples.
can u tell me how restore it and thx
Message 15 of 38
(3,147 Views)
It looks like you removed the actual example. I'd recommend saving an copy of the example in a new directory next time and working on that.
I believe you'll need to replace the a folder called "Serial Loopback" at the following directory: C:\Program Files\National Instruments\LabVIEW 2011\examples\CompactRIO\Module Specific\NI 987x (that's the directory on my machine for LabVIEW 2011)
I've attached a zipped version of the folder for you to replace the folder with. Let me know if that does the trick.
CLD Certified
Message 16 of 38
(3,145 Views)
I've attached a zipped version of the folder of my LV project
These VIs have moved from the LV example to my project
But i dont know why these errors in VIs and how to correct them
Message 17 of 38
(3,143 Views)
Hi
I have already moved the exemple to my project CompactRIO, but when i want to run a VI for example the " 900x 9870 DMA Config (Sub).vi "
I find these errors
Can u explain why these errors and how correct them
Message 18 of 38
(3,137 Views)
It appears you may not have the FPGA module installed. Do you see it in Measurement and Automation explorer under My System>>Software>>LabVIEW (version)>>FPGA
To better illustrate what I mean see the image below:
CLD Certified
Message 19 of 38
(3,132 Views)
Hi Zach-H
This my MAX:
What is missing to install ?
Message 20 of 38
(3,130 Views)
