04-17-2018 12:51 PM
I made a fairly insignificant change to the module code we wrote and have been using for over a year. This code has been compiling without any issues. I finally isolated the issue to having an I/O node on the block diagram using the NI9264.
This code has been compiling without issues using the NI9264, which is why I don't understand why all of a sudden it stopped compiling.
The error I get "Some of the compilation steps were not executed". If I disable the I/O node it compiles just fine, the error occurs both in development mode and export.
Clarification: The I/O Node linked to the 9264 is used on export only, but I was able to replicate the issue on development mode as well, all I did was place AO0 node on code and it fails the same way on export mode.
04-17-2018 02:28 PM
Using a CRIO 9038, LabVIEW 2014 and Vivado 2013.4
04-18-2018 04:18 PM
Hi isaacvega,
In general, I would ask various questions (are you using hybrid mode, does this occur with a FPGA VI with just the I/O Node, is this a local compilation). However, I discussed with the Applications Engineer you spoke with today, and it seems that it is best to proceed troubleshooting through that process.
For others that come across this, consider narrowing down the issue with using the I/O node alone in a FPGA VI. If you are using Hybrid Mode, refer to the following document: http://digital.ni.com/public.nsf/allkb/EE21CD363EDE58E486257E0E0045C9A8?OpenDocument.
