Connect to two myRIOs at the same time
Does anyone know if it is possible to connect to multiple myRIOs at once?  I couldn't find any examples, but I may have been searching the wrong stuff.  I will continue to research the topic, but any help would be appreciated.
Thanks!
(2,678 Views)
More probable over WiFi assuming they were set to different addresses.  I am not sure how the Ethernet Over USB will react.  Hopefully, the system gives them two different IP addresses.  Then it will be a simple connection to make.  You will need to have the second myRIO added to your project.
GCentral
(2,657 Views)
