Controlling three webcams with tilt\PAN zoom
I am wondering if anybody can help me:
I have a project that  use three webcam with tilt\pan\zoom capability. I am also using three cRIO (9072) for data acquisition and control. I need also to be able to control the camera remotely over the Web. Where is the best place to connect the webcam (cRIO or directly to PC) .  I have never done any project using camera and I don’t know where to start. Do I need to get any specific camera that Labview has driver for or the Labview support any camera that has USB or Ethernet port.
(3,717 Views)
Arian
You have 2 main options
1. You can use any Ethernet camera and use standard TCP/IP commands to view the images from your host computer. Then have your cRIO, connected to the same network adaptor. If you are building your own pan/tilt control you can control it with the cRio and if you are using a camera with built in tilt /pan you should be able to control that with the same Ethernet connections.
Option 2 is to use the setup designed for the FIRST Robotics teams. This set up will only work with This AXIS Camera. You can use this tutorial to see how they do it.
(3,697 Views)
