03-06-2020 08:14 AM
Is it possible to downgrade RealTime version 19.0 to 17.0.and all other dependencies?
BR
Philipp
Solved! Go to Solution.
03-17-2020 09:47 PM
Yes, that should be possible. You will need to ensure that you have Real-Time 17.0 installed on your host PC.
When you are installing the software/drivers to the PXI via NI-MAX, you should get the option to choose which version of Real-Time to install. You will likely need to match (or ensure compatibility) the version of Real-Time on the PXI, to the version installed on your development PC though.
