Downgrade Real Time module on PXI
Is it possible to downgrade RealTime version 19.0 to 17.0.and all other dependencies?
BR
Philipp
(2,108 Views)
Accepted by topic author philipp.frase
Yes, that should be possible. You will need to ensure that you have Real-Time 17.0 installed on your host PC.
When you are installing the software/drivers to the PXI via NI-MAX, you should get the option to choose which version of Real-Time to install. You will likely need to match (or ensure compatibility) the version of Real-Time on the PXI, to the version installed on your development PC though.
(2,051 Views)
