10-22-2018 02:29 PM
I have been using a cDAQ 9137 (one NI 9269 voltage output module, two NI 9234 voltage input modules, and two NI 9474 digital modules) without any problems with LabVIEW 2017. Then I decided to upgrade to LabVIEW 2018, and I have not been able to connect to my cDAQ since. I am getting Error -88900, "The specified remote target is unreachable. Ensure that the target is running." Yet the target appears to be running, from both NI MAX and the web configuration (see attached images).
I upgraded the device's firmware and all of the software installed on the target so that it matches the host and have reset and restarted the cDAQ several times. The odd thing (to me, at least) is that everytime I restart the cDAQ, it seems to start out working OK. I am using the voltage outputs to drive speakers, and after restarting the device the speakers generate a tone. Unfortunately, I am at a loss of what to try next; any guidance would be greatly appreciated.
Thanks in advance.
Solved! Go to Solution.
10-23-2018
03:28 PM
- last edited on
12-17-2024
11:16 AM
by
Content Cleaner
Hi, here are a set of steps we can follow that might help us.
10-24-2018
06:19 PM
- last edited on
12-17-2024
11:17 AM
by
Content Cleaner
Thanks for the reply. The issue has been resolved, but I don't know what the solution was. I had upgraded the DAQmx drivers after upgrading LabVIEW, so I don't think that was the issue. However, in trying to figure this out before receiving your reply, I tried uninstalling and reinstalling everything, and eventually reached a state where LabVIEW was not installed but the installer thought it was (I assume there was a registry problem). I followed these instructions to successfully reinstall everything.
Thanks for your help.
