Ethernet connection for cRio9014 using LabVIEW Run-Time engine
I only have one network card on 2nd computer. thx for the info.
Message 11 of 20
(2,775 Views)
Sam, What happens if you try to connect the 1st PC and the DAS PC with the cross cable? Is the DAS PC detecting the 1st computer? Have you by any chance disabled the network card?
"A VI inside a Class is worth hundreds in the bush"
യവന്‍ പുലിയാണു കേട്ടാ!!!
Message 12 of 20
(2,771 Views)
I am able to get the connection between 1st PC and DAS PC using crossover network cable. I am sure that the network card is enabled.
Thanks.
Message 13 of 20
(2,769 Views)
Hi Sam,
What happens if you connect the two computers and the cRIO to a router, and set the computers and the cRIO to pull DHCP?
Stephen B
Message 14 of 20
(2,744 Views)
I think this is a software issue, what software components must be installed to get this to work?
Message 15 of 20
(2,258 Views)
cRIO Software Requrements
1. LabVIEW Development System
2. LabVIEW Real-Time Module
4. LabVIEW FPGA Module (Optional if using scan Mode)
3. NI RIO driver.
These components should be installed in the order listed (RIO must be installed /updated last)
Message 16 of 20
(2,236 Views)
What about with the run-time engine?
Message 17 of 20
(2,232 Views)
All you need to install is the four (or three) components listed.
(BTW the LVRTE installs with LabVIEW development system)
Message 18 of 20
(2,229 Views)
I'm trying to do this with the run-time engine only. No dev environment.
Message 19 of 20
(2,227 Views)
If you are just trying to modify the IP address, you only need NI-RIO. This will install MAX and provide all the functionality necessary.
Mike S
NI AE
Message 20 of 20
(2,202 Views)
