FPGA 7961R and 5761R Digitizer for high speed triggered acquisition
Hi Badri and thanks for the code, I'll test it right now.
To check if the graphical part of the host VI is responsible of the overflow issue, I deleted
the graphical plot. However, the results are quite similar with or without it. Beyond 40 KS
there's a overflow and the host is unable to read all the samples between triggers.
Anyway, I'll switch to the 2 & 4 channels versions because these are the ones I really
need implement.
Message 11 of 14
(3,250 Views)
Hi again Badri,
After some days of trial and error, I've finally managed to obtain a working solution (+10KS/ch x 4 channels) using two fifos.
So thank you so much for your collaboration!
Jordi
PS: if you want the project just ask me and I'll send it to you.
Message 12 of 14
(3,230 Views)
Kudos for getting the project working.
Message 13 of 14
(3,222 Views)
I already gave you some in the previous page, please check it
Message 14 of 14
(3,207 Views)
