Fatal error: NI-Memory Manager Forced Fatal Error
Hello everyone,
I am a newbie in the NI products. I am extending my hand for help with this error.
I have received the error message after i installed the NI labVIEW2017 on the NI Realtime Hardware using NI MAX.
I have attached a photo from console for reference.
Fatal error: NI-Memory manager Forced Fatal Error: Internal memory manager error. .\source\nimm\tNIHeapPageManager.cpp:294 .
It would be really helpful if anyone has encountered this type of error!.
Any leads will be helpful in solving the issue.
Thank you.
With Regards,
Ravikiran Murthy
(1,243 Views)
l encountered it and luckily have solved it. For that case, the successful way:
1. Make the PXIe controlller enter the safe mode;
2. Connnect the PXIe controlller to PC through wire;
3. Find the controller on NI MAX;
4. Right click it and then format it as the attached photo.
(950 Views)
