FlexRIO PXIe-5775 Channel Interleaving
I have a FlexRIO PXIe-5775 (KU060) which I need to get the full 6.4 GS/s from. In the IO Socket CLIP Details section, there is the following text:
"This CLIP exposes two 3.2 GS/s AI channels to the LabVIEW diagram. The interface for each channel is 16 samples wide, hence driven by a 200 MHz DataClk.
The converter is capable of running at 6.4 GS/s though a single channel. The input can be configured for 6.4 GS/s by enabling interleaving of AI0 and AI1."
My question is, how do I enable interleaving of AI0 and AI1 to achieve 6.4 GS/s? I have not been able to find any information on this in the documentation or discussion forums.
(1,028 Views)
Accepted by topic author Cy.Rybicki
Was sent the answer to this from another source, including it here in case anyone else runs into this problem:
"C:\Program Files\National Instruments\LabVIEW 20XX\ProjectTemplates\Source\FlexRIO\NI5775\Getting Started" contains example projects for each 5775 variant, and includes "Set Interleaving.vi" which shows how to enable this feature.
(996 Views)
