How do I set IP address from the console
I have several cRIOs and I want to change their static IP via the console. What are the commands I need to execute to set the IP address on the cRIO via the serial connection?
Patrick
(7,090 Views)
Hi Patrick,
You cannot control a cRIO with the serial port, it is used only for reading the status of the controller.
Otherwise you can set the IP of a cRIO from:
  • Measurement and Automation Explorer (MAX) by clicking on the targe and selecting "Network Settings"
  • System Configuration VIs
  • FTP, open a session and update the "ni-rt.ini" file.
Will one of these options work for you?
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(7,059 Views)
I would like to change them from MAX, but I keep having trouble with MAX detecting them, even when my laptop is in link-local mode with 169.254.x.x and 255.255.0.0. So far I have had to go into the console to see what IP the cRIO is creating for itself and then I have to manually add the device in MAX using the address. I was hoping that I could cut out a step using the console to do a simple "ifconfig" (like Linux). It looks like I need to continue my method on the remainder of my cRIOs until I get their IPs to my desired static setting.
(7,051 Views)
Patrick,
Make sure to check all the steps in this documentation: http://digital.ni.com/public.nsf/allkb/abe4bc247e8ac9bc8625734e005cab42?OpenDocument
Primarily make sure your firewall is disabled. MAX should be able to discover devices on your subnet easily.
Also, newer versions of the NI-RIO driver are generally better at discovering devices.
RIO Driver Search: http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du/q/rio/
The latest version at this time is NI-RIO Device Drivers August 2012.
(7,044 Views)
