How to measure a reed switch with C-series cards.
I need some help trying to pull reasonable data from a reed switch. The setup that makes common sense to me is the one I am currently using. I have a resistor between the switch and the NI PS-15 power supply in order to step the current down below 20mA. The normally open reed switch is a two wire instrument where the impulse is measured across the two wires. My engineering common sense dictates that I should use a NI 9203 C-series card to hook up to my cRIO-9073. This is because the 9203 is a current input module. As the reed switch is normally open, the current should register as 0. Then when the switch is closed, the current flows to the card returning a readable value. The switch has an LED embedded within the sensor itself so I can physically tell when the switch is closed. However, the 9203 card is not returning any value greater than around 0.1 microamps. The current across the resistor I measured at around 15 milliamps. I am terribly confused and if anyone would be able to offer help or guidance that would be phenomenal. Thank you for your time.
(2,155 Views)
Can you make a diagram showing exactly how this circuit is wired up?  My first thought is that you did not wire the 9203 channel in series with the resistor and power supply return.
(2,070 Views)
