10-04-2019
		01:24 PM
 - last edited on
		07-12-2024
		05:25 PM
 by
			Content Cleaner
Hi all,
I just purchased AO module NI 9262 for my compac DAQ system (cDAQ 9174). However, in the NI MAX, it shows as "unsupported" cDAQ module. However, in the following NI web, its showed 9262 is compatible with cDAQ system.
I also tried this module (NI 9262) on my compactRIO (cRIO-9056) system. Now the module is recognized. But it seems this module is only FPGA module?
So may I have two questions here?
1) Is NI 9262 compatible with cDAQ system or not?
2) Can I control NI 9262 using DAQmx API instead of Labview FPGA?
Thanks a lot
Elliot
Solved! Go to Solution.
10-06-2019 07:16 PM
As of the latest DAQmx 19.5 driver, NI 9262 is now supported for CompactDAQ module. You need DAQmx 19.5 driver and anything else will not be supported.
10-09-2019 10:48 AM
Awesome. Thanks a lot
