Lost the password to a CompactRIO and need to update the Real-time version: What are my options?
I am a grad student that has been tasked with modernizing some neglected testing equipment. The system runs on a CompactRIO 9082 and the last time it was used was 2015. Most of the documentation has been lost since then. On top of that the daq is password protected, which I don't have. Nor can I get. I am currently unable to communicate with the CompactRIO due to an outdated real-time module version (version 2014). I understand that I can reformat the daq in order to reset the password but I don't know what files or the FPGA that is uploaded currently.
What options do I have?
Is there a way to work around the need for a password?
Is it possible to flash the daq drive to a portable drive and analysis the data that way?
(2,158 Views)
You can try to long press reset buttom (for 30 seconds, or maybe longer), till the status led is blinking at a different speed, there you go, the CRIO is complete resetted, including your password.
(2,063 Views)
Jiangliang,
I have already looked into resetting the CRIO. But resetting the device will erase any existing programs on the daq. I would like to be able to salvage these VIs if possible.
(1,927 Views)
